and a breaker bar, should be able to get it out i its the one pictured.samxini wrote:PB blaster?
+1Steve Lloyd wrote: first, unhook the plug..........
i took the plug out before the pictures....thats not the thing holding the distributor in. Its something thats on the inside. No idea....Steve Lloyd wrote:spin the distributor in either direction and it will slide right out, but first, unhook the plug..........
Yea i'm overdue on an oil change. But nonetheless, i took the cover off and was like WTF myself. I seafoamed it before the last oil change. :-\PapaSmurf2k3 wrote:
+1
And change your damn oil every now and then... I've NEVER seen a top end that dirty.
its auto :-\ but i put it in neutral...same thing. Rocking it while pulling it...tried it to no avail.clss240 wrote:unhook the wire silly.
seriously. make sure the car is not in gear. crank it over a sec then try again it just might be under a little bit of pressure. from the gears in there. you shouldnt need any prying tool to get it off simply rotate back and forth while pulling on it.
i dont think so. you just need to twist slightly. dont force it out . push it back in and twist a bit in each direction. nothing holds it in.nightsauce wrote:omg thank you sir...i was looking at factory manuals to try to get some information, i wanted to see what it would look like out of the head. does it have to be cranked to a certain position for it to come out. I had it at TDC...maybe i was a few degrees off.
push it back in and try rotating in either direction.nightsauce wrote:its weird man, you say nothing holds it but mine is like the biggest b*tch in the world...took me half hr just to break the seal from the head. Then it was sitting there. It was able to rotate about 40* but didnt come out.
pour some penetrating oil on it. drill a hole in the remaining part of bolt. the drilling will break the rust bond. they have special bits that will dig into the bolt remnant and pull it outnightsauce wrote:i hope i didnt damage the gear by forcing it. i see how it works now thanks for your help. I'll try to take everything back apart this week, but i have a bolt that broke off in the front plate/distributor. I'm going to have to do somethin about that...might take it somewhere just to get that bolt out.
yea my top end is pretty dirty. I'm gonna pour the last of the conventional i have into the top end to maybe get some dirt or w/e on the way down. Them i'm goin to switch to synthetic.Razi wrote:That is a pretty nasty top end.Try cleaning it up a bit and pouring some clean oil over it before you finish.
Maybe switching to synthetic will clean things up.
