Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Mon Oct 23, 2006 5:47 am
I have the SSAC mani, it will work fine for my purposes. While there have been issues in the past, the new generation is coming reinforced. I am using a Tb03 from the Z31, that I put a T04b V trim on the compressor, and balancing the assembly with a ceramic coat. Super fast spool with a T4, NICE!
Where did you find that GT32, though?
As far as oversizing, don't do it for the sake of oversizing. Check ring gap with new rings, and the block honed. If you are in spec, do not overbore. This could save you issues with overheating, next rebuild, etc. What if you blow it up and marr the walls, what do you do next? KISS... Keep It Simple Stupid (not calling you stupid, it is just a saying...)
EDIT: Issues with mani are MC clearance. In the S14, the mani fits like a glove. In the S13, the turbo needs to be on center, which as far as I know, never was an option with a T3 (but yes on a T4, which the mani will take both). So I changed my motor mounts out with hockey pucks, to roll the engine over.
