rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Tue May 06, 2008 2:17 pm
OK, so here's the problem, when I start my car in the morning, it usually idles for about 30 seconds, then floods out and takes 5 or 6 tries to start it again. Once started it misses and hesitates and won't rev beyond idle no matter how hard I hit the gas. Actually hitting the gas seems to make it worse.... for about 30 seconds then suddenly goes back to normal. Seems fine till I put it in gear, it runs properly till I let the clutch all the way out, once the engine is under load it then floods out again and won't accelerate AT ALL, for about 30 seconds, then it surges and hesitates its way to 3k rpm. It runs fine over 3k rpm. This process repeats for every gear for the first few minutes of driving.
Once warm, it will run perfectly about 25% of the time. The rest of the time it will either run one of two ways.... 1. It will not idle (stalls, and if you keep it from stalling it misses constantly and smokes), and make LOTS of power and is very sensitive to throttle, (like the throttle does nothing till 25% then the car SURGES forward) almost like the gas pedal is an on/off switch, either full acceleration or none. Also the car smells VERY lean when it runs like this. 2.the other way it'll screw up is the way mentioned before where it will idle fine, but when you hit the gas it INSTANTLY starts missing and surging and stumbling and hesitating it's way slowly to 3k rpm, then it runs perfect from 3k to redline.... Also when it's stumbling and missing the more gas you give it the more is stumbles and misses.
Ok, so here's what I've changed chasing this grimlin... Fuel filter, plugs, wires, cap, rotor, o2 sensor, MAF, and CTS
I took it to a shop about a month ago to get this fixed and he said it was running extremely lean and the MAF was causing the problems, he said my old MAF tested fine, but it runs signifcantly better with the one that's on it now, which also tests fine, and is from a 240 parts car. He also added an extra ground wire to the MAF wiring harness to help it and it ran ok for a few days, then when I went on a 300 mile trip that week it started screwing up again and went right back to it's old screwed up ways. The guy at the shop said I'd have to get a air/fuel controller to fix the problem....
What strikes me as odd is that it ran perfect up untill 4 months ago, and it started doing this all of a sudden. And every now and then it'll run perfect for a whole day... then it goes right back to screwing around again for no reason at all. And when it changes from running perfect to running snappy to running horribly, it's like somebody threw a switch. It's not gradual at all, its like one second it's fine the next it wont run.
So I want to open this "issue" to the experienced NICO members opinions to see WTF is wrong with this car. Cause I'm at my whit's end and I can't afford to keep throwing money at it and not fixing the problem.
In short HELP!!
Modified by rsmithdrift at 12:56 AM 5/8/2008
