KA-DE No Fuel To Cyl. 2 & 3.
Pro ViZion
Car: 1990 Nissan 240SX w/ KA24DE
Im trying to get my swap started and im not getting any fuel to cylinders #2 & #3. When im cranking its popping all the time at number 1 and 4. i know they are getting fuel because they have fuel on the spark plugs. the others do not.
I have insured that timing is set correctly and everything is hooked up.
biggie
Trying swaping ECU? Injectors tested?
Pro ViZion
Yeah im gonna try that. I have ohm tested all the injectors, comes back 11.2 ohms for each.
biggie
ECU/wiring would be the best current bet.
Pro ViZion
is it pretty common for these ecu's to go bad? I see alot of threads were simpling swapping out the ecu fixed the problem.
biggie
During swaps believe it can happen, I've never known a one to go bad without major work happening to the car/wiring.
Pro ViZion
Turns out it was the ecu. Put it in a friends car and it didnt want to start at all. So i bought a new ecu and played with the timing a little bit and she fired right up.
