KA-DE MAF on Redtop?
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Will a 1995 KA-DE maf work on a S13 redtop? If so what wires match to what? I've searched this and came up with nothing but others selling KA mafs. I planned on using mine until I can get the $$$ for a Z32 unit. Thanks Josh
Gramentz
Car: s14
You can use the single cam maf.
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Alright, I'll try to find one around here at a junkyard. Thanks
Gramentz
Car: s14
No problem. Someone on the forums may have an extra one. I picked mine up at a junkyard for 50 bucks..warranty included.
S13FASTBACKSR
Car: '92 Fastback SR powered
BLKTOPS14SR wrote:Alright, I'll try to find one around here at a junkyard. Thanks
or you can buy my stock sr maf...if you are interested email me at [email protected]
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
A friend has a R33 GTS RB25 Maf. Would that work and if so whats the wiring like on that? How is it compared to the Z32 MAF?
S13FASTBACKSR
my guess is it has the usual 12v and 5v wires and then 1 or 2 grounds...so it is probably straight forward yet at the same time you have to find which pin on the r33 maf is 12v and which is 5v and which are ground..if you get this wrong and then start your engine your ecu is toast ...by the way you will have to reflash your ecu with this maf and also by the way i emailed you a price for the factory sr maf
