jmhalder »
https://forums.nicoclub.com/jmhalder-u26798.html
Sun May 01, 2005 8:32 pm
GEEZ LOUISE!?!?! you have the cam timing off by enough that you have valve interference? although i dont really want to explain how to do it right, as a general rule of thumb, when the engine is at TDC on cyl.1, (refering to 1st lobe on cams) the intake lobe will point STRAIGHT to the left, and the exhaust cam lobe will point STRAIGHT to the right. the only way to be REALLY sure, is to pull off the front cover and time it to the reference point on the upper drive sprocket, thats what i ended up doing after a very annoying 248/248 install... it seemed that every time we took a stab at it, we were off a tooth in some direction on 1 (or both) cams... although i guess i didnt really awnser your question about the color of the cams, that (i believe) can be awnsered in the stickied post in KA section, about cam allignment... they mention color of the cams in there.
