ka cranks but wont start, no spark no injector pulse HELP!
andre's240
Car: 1990 240sx s14 KA swapped
i have a 90 240 that i recently put a 96 ka24de into, i had a customharness made by chase bays for the swap.. all wiring is done correctly and everything is connected to the proper spots, changed dizzy cap and rotor but still no spark or inhector pulse. yes i know im a noob but i need help so it would be greatly appreciated... thanks in advance
Warped161
Car: 90 s13 the never ending project
grab a test light or a multi meter and start back tracking your wire harness till you find voltage and see where your losing it. could be the harness, could be the cpu.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
FSM will have all of the info you need.
andre's240
i have a multi meter but where should i start? i used a lil light bulb to test the injector pulse and it didnt light up.. bare with me im a naive teenager
asoomal
Never use a test light on a component that is connected to the ecu!
You will need a noid light to check for pulse, a normal bulb is too slow.
forums.nicoclub.com/240sx-fsm-full-service-manuals-s13-s14-ka24e-ka24de-t311075.html
Just follow the no start steps.
I'd post what to do but I'm on my phone and I can't open pdf files -_-
andre's240
thanks for helping.. ill see what i can find in the fsm
andre's240
ok, checked pretty much everything all the way back.. theres a relay right next to where the harness plugs into the ecu and when the car cranks the relay gets hot, this leads my dad to believe theres an open circuit.. but where? sorry i cant post pics atm bc my computer is broken so im posting from my phone
asoomal
Which relay?
Warped161
pic of the relay any identifying marks?
greasemonkeyjunky
Car: 96 240sx
check your grounds. Ive come across as problem with at least the injector pulse because of a loose ground. good luck!
drz1ll3st
Car: 91 s13 abs vlsd hicas daily!
96ka on 90 body.. Make sure u check crank positikn sensor on top of the trans. S13 ka had it inside the distributor. Obd2 changed it to transmission. Double check that also, accorfing to fsm.
andre's240
already have the sensor on top of transmission.. i cant post pics bc my computer is broken ive been posting from my phone
edit: and my grounds are good ive checked them numerous times
andre's240
still need help.. master tech at cherry hill nissan pointed me in the direction of a new ecu.. but still just cranks, no spark, no injector pulse.. please if theres anyone in the south jersey area that is good with wiring, come help me and we'll cook you a nice meal and get your beer of choice, i really need this car back.. cant go through my senior year without a car
Warped161
sounds like a def possibility, no spark and no injectores. if all the wiring is sound then an ecu swap may be in order.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Have you checked for power to the ecu? Codes? The ecu has to be on to give spark or injector pulse signal. Do you have power and ground at the cas? If ecu is on, then the cas (in the distributor) must be working to give you inj pulse and spark. Does the eccs relay (on s14 its by the ecu) work? Do you know how to test a relay? are you getting power to the eccs relay? ”I checked everything” is to vague and obviously you haven't otherwise the car would be running. Post what you HAVE tested and maybe we can guide you through the rest.
