Jornez »
https://forums.nicoclub.com/jornez-u100011.html
Sun Jan 16, 2011 2:28 pm
Well it all started from a weird whining noise whenever I would shift hard, I was told my clutch wasn't engaging all the way, so i needed to change my master cylinder. So I changed that and bled it and did all that jazz and the pedal wouldn't come up, so i changed the slave and it still wouldn't. Ive bled it a crap ton of times with several different methods. So i was told to check my clutch fork and make sure it was okay. I don't rightfully know how to check it. But I know it moves back and forth, up and down, side to side (etc) with no resistance. What could be the problem? Is that it? I have a new clutch kit on the way (clutch, pressure plate, throwout bearing), and I have a back up trans.
