NISTECH wrote:your over heating it. the gauge is not representing your true engine temp since coolant isnt really hitting it. Try topping up your fluid and see if this still occurs. If your car has actually overheated to the point that internal engine noise is heard you have suffered some level of internal engine damage. how extensive will be hard to tell till you get it running correctly and moniter your fluids over the period of a couple days to a week. I suggest your change the oil as well since it is obviously contaminated.
most def right about that one, the water pump was gushing fluid when i poured fluid in the resivour. it leaked out so fast i dident even notice, prob when i was driving... i replaced the water pump flushed the coolent and changed the oil, it must have burned 2 quarts of oil. did it get so hot that it burned it off? its now running fine but when it gets a normal operation temperature there is slightly more valvetrain noise than normal but it feels like it runs better than ever. have any idea what could have been damaged when it was running with basicly no coolent at all???
thanks for your help, at least now its drivable.
