4gotn1 »
https://forums.nicoclub.com/4gotn1-u25219.html
Sat Mar 26, 2005 8:48 pm
i disagree on the exhaust system, i have obx header, test pipe, and 3in catback, and i have plenty of low end. infact on the dyno i was making 90% of peak torque at 2000 and held it there till 5500 (peak) and slowly dropped from there till 6500. i also have a sohc, and alot done. but sounds pretty good. i would suggest while you have it apart throw some e pistons in and run 11:1 comp. deck the block too. as for header i would recommend a hotshot or obx. i like mine. maybe some pulleys. an electric fan. that really helps the engine rev. port match the intake and exhaust. and what year is it? if it 95 and newer then go find some 91 cams from a junkyard.
