no need to be a wise arse let the moderators do their job. this is a bad time for me!574-240sx wrote:Well your tensioners were bad. Taking the upper cover/guide off didn't do anything but make it worse. You are suppose to chance you timing chain, guides, and tensioners every so often. Sorry about your motor. Yes, there is a 240 general section and No, this is not it.
I'm not the one using profanity and no being a wise(I'll put in the word bottom) you are being a pain because your stuff broke and you are trying to take it out on someone. What are we suppose to say other than sorry that your motor quit. I don't see you thanking people for their support. Your title was very vauge. I was saying, you might get more of a response in the 240 section seeing that its a 240 motor and the common timing chain tensioner problem. Some people don't like to see 240 problems in the Nico general chat, that why there is a general chat in the 240 section. You might be able to find a good motor in the junkyard or a local selling after swapping a motor for a decent price or a fraction of a new rebuild if the warranty doesn't work out.Tsukai240 wrote:
Exactly. Put back everything you removed and keep your mouth shut.krazy skwerel wrote:Well i wouldnt tell the people who built the engine that you removed or tampered with anything. They may void your warranty
jeez man the last thing i need is someone bustin my but about where i put a post. i just thought i could get a faster responce in general chat. if its such a problem to you why don't you get the moderators to move it . i don't see anyone else complaining. i'm not blaming anyone i'm just trying to get an idea abou what happend and what i should do about it.574-240sx wrote:I'm not the one using profanity and no being a wise(I'll put in the word bottom) you are being a pain because your stuff broke and you are trying to take it out on someone. What are we suppose to say other than sorry that your motor quit. I don't see you thanking people for their support. Your title was very vauge. I was saying, you might get more of a response in the 240 section seeing that its a 240 motor and the common timing chain tensioner problem. Some people don't like to see 240 problems in the Nico general chat, that why there is a general chat in the 240 section. You might be able to find a good motor in the junkyard or a local selling after swapping a motor for a decent price or a fraction of a new rebuild if the warranty doesn't work out.
