ka bogging at 3k?
murderrsirenss
Car: 92 Nissan S13 vert.
OK, when im driving and I hit the 3k-4k range my car just starts bogging and acts like its not getting any air as if the maf was unplugged or something. I have replaced the o2, and cleaned the maf twice. Ive listened/looked around for a vacuum leak, but dont really see anything. I have also filled it up with gas and added heet water remover to make sure there was no water in the gas tank.
Any ideas? I tried to make a video with my phone, but it was horrible so im not going to bother to post it.
murderrsirenss
Also, Fuel filter has been changed.
neverlift
check out your grounds
murderrsirenss
Anything else?
murderrsirenss
help, still having this issue. Getting worse by the day. Bout to make me set my vert on fire. :mad: :mad: :mad: :mad: :mad: :mad:
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Check TPS voltage, perform sweep test.
neverlift
maybe wires? cut the car on at night in a very dark area and watch for arch.
murderrsirenss
Well I just cranked the car and unplugged the maf and the idle raised a little then went back to normal, bad maf, correct?
asoomal
I think that's just limp mode, I could be wrong.
Have you tested the MAF? Also there was a TSB on it a while ago, add an extra ground for the MAF.
Anywhere is fine, body or intake manifold works.
