KA automatic conver to 5 speen ( maybe sr in future ) help
newpuy
I need comment about sr and ka I know that a lot people talking about it but I need the summery if anyone could help me outright now my car is 139000 miles I guess my transmission will go very soon so I am thinking to conver it to 5 speed for now ( money matter ) I need to know what part I need in order to conver it. and will the manual transmission fit on sr ???
other matter is that. I know right now a lot of after market make turbo of KA so should I swap to sr later ?? or should I stay will ka and build it little by little and put turbo ??
if people ask me what do i need for my car i would say that I need good gas mileage and decent power
so anyone please suggest me
( I believe my topic should help me and other as well )
thank you for you comment I will wait and read all of your suggestion
Touchdown038
Car: Computers, cars, sports
You need everything that a 5-speed car has that you don't, so transmission, clutch, master cylinder, pedal assembly, ECU, and pilot bushing. I'm sure there's more, somebody else should chime in soon.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
No, the KA transmission will not bolt up to the SR.
For the 5spd you'll need:
Manual trannyneutral/5th gear/reverse/MT VSS sensorsMT crossmember and boltstranny mountMT driveshaft for your application (ABS/NON-ABS)pilot bushingthrowout bearingclutch fork/fork pivot/throwout bearing spring retainerMT clutch and brake pedal assembliesMT clutch hardline/softline/bleederMT slave cylMT clutch master cylclutch and pressure plateflwheel and MT flywheel boltsMT backing plateMT engine boltsshifter assemblylower shift boot/plateupper shift boot and finishing plateand MT ECU (optional)
-Dan
NISTECH
oh and dan left out the MT clutch dampner assembly tube and block...
You dont really want those things though.Just messin with Dan.
Dano
Scott failed to remind me that u need the Nismo urethane pedal stop ($114.30) and the NOS WOT switch (pedal mounted of course)
j/k, joking rules!
back on topic, good luck with you 5spd swap
-Dan
