WI_S14_Goldie wrote: Transition?? How would u do that? (half synthetic and half other...)? would that be safe? why cant i just use synthetic right away?
Well, it depends on how confident you are on the condition of your seals. I have heard from several different people that if your main seals are weak, a switch to full synthetic will cause it to leak or fail completely. Others say that they have not had such a problem. Not being one to take chances with the health of my car, I usually do one or two oil changes with a synthetic blend before stepping up to full synth. Each time I've done that (5 cars and counting), I've never once had a problem.
Another method I've heard about is a four part process. Basically, the KA holds about four quarts of oil. So, the first change would consist of three parts dino, one part (full) synthetic. The second would use two of each. The third, three to one, synth to dino. And, finally, all synth. It sounds good in theory, but it seems like a bit much to me.
Anyway, that's my response for you. By all means, feel free to seek a second opinion, as I'm not the most technically proficient member on this board (by a loooooong shot). I just know what works for me.
