darkforcejackal »
https://forums.nicoclub.com/darkforcejackal-u12107.html
Tue Jun 06, 2006 6:21 am
As weird as this may sound, i've had the best launches at 4-5,000 RPM drop-clutches while NA. You'd burn some rubber sure, but when all is said and done you haven't bogged and 1st is over quickly. Just make sure to feather the gas somewhat at first, then you can go straight into 2nd at redline.
Now, with KA-T at 6 PSI and a lightened flywheel, i've had the most luck with feathered 2,500 RPM launches. You just get PULLED forward. Seems to take advantage of the KA's torque and spools the turbo before you start moving.
