ka alternator use on sr20det
gsxrbg
does anyone know if you can use the ka24e alt on the sr just wondering..if so is it a direct bolt up or do you have to modify the brackets???
rawphusion
Car: 1993 240sx, 1996 G20, 1993 S10
i was told that you could use the KA alternator, Starter and Trans as direct bolt up items. Only thing the trans wouldn't be as strong as an SR20's
SpeedRacer1
Car: 1990 240SX, G35
Starter no, transmission no, KA24DE alternator yes if you swap the pulley off an SR alternator. May not need to swap the pulley.
virus77
Car: 95 S14, 71 240z, 97 e320
you can use a KA24de starter if you swap the mounting section with the SR starter, and with a bellhousing swap you can use the KA transmission which is no weaker than the SR transmission. neither are a direct bolt on but it can be done.
mallbor240SR
Car: 240sx 1990
would a ka24e (sohc) alternator work on the SR? o do i have to get the ka24de(dohc) alternator?
sr20-thoj
Car: 89 nissan 240sx coupe
I am also in need of a new alternator too.. Which one would fit the sr? both sohc and dohc ka? how would you swap the mounting section also?
virus77
mouting section was refering to the starter.
KA24DE alternator only and possibley your SR pulley. Im sure when its in front of you it will be pretty obvious what needs to be done.
PAsrfreak
Car: 95 240sx SE
i bought an alternator for a 91 sentra se-r -by switching the front case and bearing from the original sr alternator onto the se-r alternator, it worked fine. A little more involved, but not too bad
scottsnissan
Car: 1995 240 sx se
I jus did the swap from a ka24de alt to sr alt.All i did was have the pully removed from sr alt to the de alt.THen u have to drill out the top hole.If u notice on the de alt it has threads and sr it dosent.As far a fitmint all waS great.
mallbor240SR
Car: 240sx 1990
i just did mine and besides drilling the top hole, and swaping the pulley i had to use a washer between the pulley and the alternator. it works great.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
So....what if I don't have my SR alternator??? WTF alternator can I use? will any other alt just bolt up? come on...
Can a FWD SR20/SR18 alternator be used?
aucerumo
Car: 07 Versa and 1985 Ae86
ka24de works fine but u have to modify it abit. for ka24e u cant used it because its from a single cam engine. when u put it on the alternator would be overloaded and the battery would bust. sr20det is twin cams.
Blown240sx
Car: 1996 240sx
aucerumo wrote:ka24de works fine but u have to modify it abit. for ka24e u cant used it because its from a single cam engine. when u put it on the alternator would be overloaded and the battery would bust. sr20det is twin cams.
WTF does DOHC and SOHC have to do with altenator output? I could have 20000000000000000000000 cams and the pullys would still turn the same to make the altenator charge.
Also the SOHC starter is a direct swap for the SR starter all you have to do is switch ou the heads which is 4 bolts and they should only be hand tight or you will strip the aluminum head from the SR.
Also KA and SR trans internals are the same.
