KA alternator on RB motor how??
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I know a few of you have done this, Which year KA alt do you use? and how did you make it work? Plz show me some pics of what you did so I can do this.
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
I am unable to show you any pics but i used the altenator from my '90 SOHC KA. If you take a look at the bracket that holds the top of the RB altenator, it has two mounting holes that use bolts for the waterpump. When looking at the holes, there is the one closest to the altenator, and the one farther away from it. What you need to do is slot the one closest to the altenator allowing you to swing the bracket down about a half an inch or so. Bolt the bottom of the altenator to the plate and you will see what i mean when you swing it up to meet the top mounting bracket. It's not too hard if you have something to slot the bracket with. Good Luck!!
SeVa-S13
Car: '05 GTO 6spd
klh got it pretty well. Just grab a drill/dremel and look at it -- it's a quick job.
Yellow4g63
klh6686 wrote:I am unable to show you any pics but i used the altenator from my '90 SOHC KA. If you take a look at the bracket that holds the top of the RB altenator, it has two mounting holes that use bolts for the waterpump. When looking at the holes, there is the one closest to the altenator, and the one farther away from it. What you need to do is slot the one closest to the altenator allowing you to swing the bracket down about a half an inch or so. Bolt the bottom of the altenator to the plate and you will see what i mean when you swing it up to meet the top mounting bracket. It's not too hard if you have something to slot the bracket with. Good Luck!!
I remember trying to use my KA alternator and I couldn't get the bottom part to bolt up to the motor. I couldn't put that little spacer thing in because the size diffrence vs the RB alternator.
lyon23
Car: 95 240sx
what I did was connected the alternator at the bottom first then I saw how much the bracket need to come down..also what you can try is after the alternator is connected at the bottom put put only one bolt on the bracket the one on top, then move it down to where it meets the alternator and see where the other one needs to go.
from the picture bellow you can see on 1.. where the second bolt at the bottom is and you would dremel it in the direction of the arrow in order to make 2.. move towards alternator where you can make it work
if you can wait till tomorrow I can post a pice of the bracket.
Yellow4g63
I'm not in a rush I can wait. what about the spacer on the bottom. I looked at the KA alternator from my SOHC 89 and one part of it's thicker than the RB so I couldn't get the spacer to fit to bolt it on to the motor.
klh6686
'90 FB w/ RB20
'92 FB w/ VH45
i have no idea what you are talking about as far as "the spacer" goes. My altenator just had the two brackets on the bottom and the one up top. I pulled the rb's alt off and stuck the bottom of the KA alt directly on the bottom mount plate. I then place the long bolt through the hole and bolted the bolt to the back. Maybe the bolt is what you are talking about? It isn't a normal bolt as it inside a rectangular peice of metal, if so this goes on outside the altenator not inside the bracket. If not, im sorry, i just don't know what you are talking about.
Yellow4g63
The spacer I am talking about is at the bottom of the alternator. It's a cyclinder shape and the long bolt goes through it. Damn I'll take some pics when I get a chance. If you see it you will know what I'm talking about.
lyon23
Car: 95 240sx
Yea I know the spacer that your talking about I put it in between the back bracket and the alternator.. I make sure that the alternator is as much to the front as posible..
lyon23
Car: 95 240sx
this is another pic
Yellow4g63
Thanks for the pics. I'll do the install this weekend.
