480sx wrote:Oo shiny Whyd you have to come in here with something for sale that i would spend money on? Man dont you know what your doing to us Ka-Ters?
I think a set would look great anodized to match your engine theme.
Being a KA-T enthusiast myself, I understand completely.
Quote »However i do want some things discussed about them. From prior knowledge the lightened pulleys themselves might give you 1-2 hp.[/quote]Can you be more specific about your prior knowledge and the specific application, because I disagree. Depending on the size and loss of rotating mass, I've seen that much whp gain per pulley. The UR underdrive crankshaft Pulley on the SpecV yields 2-3 horsepower, and its the same size as one of these accessory pulleys. Also, WRP technology makes a power steering pulley for the SpecV that supposedly shows the same gains.
I think we will see 4-6whp gain with the accessory pulleys alone. I'm in on the group buy myself, and I wouldn't go through all this trouble if I thought it was a waste.
Quote »The HP gain talked about in that thread is with the underdrive pulley. The underdrive effect is what gives 90 percent of that HP gain. So at 245 for just the discontinued pulley set, your pretty much spending that cash for show IMO. [/quote]I was very careful to note in the group buy that the gains listed were with the crank pulley, but you have to admit that 90% gain from underdriving alone is an exaggeration.
Again, I point you to the SpecV, where the underdrive crank pulley yields only 2-3whp. The one for the KA yields at least twice that because it is a larger pulley, so it sheds alot more weight when made out of aluminum. If 90% of the gain came from underdriving alone, there would be no way to explain the disparity in whp gains between the two applications.
Either way, you know as a fellow KA enthusiast that every little bit helps. This is especially true for those N/A guys trying to reach 200whp. 12whp for under $500 (including crank pulley) isn't a bad deal at all when you're NA. SpecV people spend hundreds more for much less.
Thanks for discussing this and clarifying the point about the gains being with the crank pulley. I hope you'll get in on the group buy, for show if nothing else.
