Red coupe wrote:just to clarify turn the key and the engine just cranks at normal speed, but doesnt start at all or starts a little then stumbles and die, or does it crank kinda slowly just barly turning the engine over each time?
It turns pretty normally without starting, but sometimes it seems like it is going to start; that's what's annoying. If I push the car a few feet and try to start the car again it pulls more strongly, but still without success. That kind of led me to believe it could be the contacts on the starter. More of a guess than an educated analysis, really.
For spark I grounded the plugs on the block turned the key, getting good sparks. The fuel pump works and the ecu doesn't complain about the injectors. I do also smell gas when I crank it for a while. Thanks for the reply.
