Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Thu May 08, 2008 10:42 pm
If you have the ability to re-build your own block then it will cost around $1,000 depending on your machine shop cost. The money spent on the MAF etc is not waisted as they are all external to the engine and can be used after your rebuild.
Once you rebuild the block with alll those new parts I would say just add a new fuel punp and you should be good for another 100,000 miles with just regular maintance for a daily driver. Less if you race etc.
Total cost of 2,000 to 2,500 for what you have allready spent then the re-build is not bad for a 100,000 mile car.
