Thecollector wrote:My only question is whats the point? I dont see it. With brake lines, it helps apply the pressure on the calipers and not in the expanding of the lines, but a clutch line? Supposed to make you shift easier?
SHIFTrl240 wrote:the k2rd one doesnt replace the factory loop, just replaces the stock rubber line from the hard line to the slave.
to take out the dampener block, just undo all of its connections, unbolt it, then bend the hard line coming from the master cyl around so that it goes to the slave line directly. have to do this without kinking the line though.
heres a website that has some pictures of the modification:http://www.zeroyon.com/pics/in....html
nightwalker wrote:nice little upgrade for the factory rubber line. Sometimes that line is so old, it won't hold the pressure, and the car will creep forward even if you have your foot on the clutch pedal. It may also happen after some spirited driving, due to heat.
stillmatic wrote:Here's another writeup on how to remove the clutch dampener: http://sr20.hybrids.jp/install....html
It's so easy. Just unbolt the hard line from the master cylinder and also the one from the dampener to slave. Connect the master cylinder hard line directly to the slave and replace the stock rubber clutch line with stainless steel if you wish. You can take out the dampener if you want to or just leave it in there. Rebleed the clutch and that's it. It should take about 30 mins at most.
