sil80drifter wrote:I am sorry but if ur really troubled because of hot air in ur intake (and be it AEM or Injen, after a while the piping WILL heat up no matter what the wrapping is), you shoudl do this: relocate battery to trunk, cut a hole in the battery tray big enough for a 3 inch pipe, relocate ur windshield washer tank to where your air resonator is right now (remove resonator before that of course), order a MAF adapter and K&N air filter, make your own custom piping, and put that bad boy together, so you will have a good cold air intake unaffected by the hot hot hot radiator. That's what I'm doing within the next 2 weeks, and as soon as I am done, I will post exact directions and pics.
p.s.: Also cut a hole in the frotnof the bumper, for better air access to filter.
sil80drifter
wow... your radiator must run REALLY hot for you to go through all that trouble. I can assure you, it doesn't get hot enough to heat up my intake tube to any noticable degree. And, If you've ever held your hand partially over the end of the intake tube while the car is running, you'll see how fast the air flows through there. If you push the throttle down, it will suck your hand into the tube. The air is flowing FAR TOO FAST to be heated up even if the tube temperature does increase. I've driven in stop and go traffic for hours at a time, no air passing the radiator other than the electric fans..... and it never got hot, neither did the intake.
