K&N style filter
dak2007
Car: umm.....working on my car duh
alright i found a cheap K&N style filter at autozone the only problem is it didn't come with any type of mount for the o2 temp sensor. i tried to instal it without the sensor but she didn't run too well...can i do anything without installing a cold air intake:spam
Touchdown038
Car: Computers, cars, sports
You can mount it anywhere near the cone, because that is around the same temperature air that is sucked into the intake.
dak2007
but how do i mount the filter onto the sensor...the sensor comes out to a square piece and the filter is a circle piece.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
you need a nissan MAF adaptor plate. most places that sell performance parts can get them. probably like 10-20$
Touchdown038
Are you talking about the mass airflow sensor? If so, you need to get an adapter to attach the filter to the metal housing that the sensor sits in. It SHOULD have come with your K&N kit, but if not they're pretty easy to find.
IvoryJ30t
its bolts to the MAF using the square 4 bolt pattern, and has a cylindrical end that you clamp the filter to.
dak2007
that's it
Axel Grungy
Car: 2001 G20 5spd
go on ebay they have tons of those for cheap
