K&N or Intake
victor_s14
This is a simple question, Is a K&N air filter for a 98' 240 any good? or will I get more horses from a short ram intake (what kind of intake). Thanks Guys
APEXi240
Car: 08 Nissan Versa S hatch
probably get 1 or 2 more hp from an intake. I have a K&N.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
ull get more hp from a short ram intake than using the stock airbox, i have an AEM shortram and got it for $144 shipped from http://www.e3racing.com ...good luck!...
-Dan
blackbeauty240
Car: cooking, fiddeling around with different cars
get the intake
sixxdeuce
Car: 93 rx7, G35coupe 6mt
If you get the k&n remove the resonater and get some flexible aluminum ducting and run it from the bottom opening in the bumper up to the holes in the airbox, that way you will be getting outside air not drawing in any hot air from under the hood, like a short ram does. Probably the best option is to get a true cold air intake the draws air from the fender well.
I am Technoman
Car: ???
i got 6hp from an hot shot intake
S-14boy
Car: 1998 Nissan 240SX SE
I have an AEM short ram, I used to have a drop in K&N before that, I feel more torque with the AEM short ram vs the K&N, the AEM sounds a whole lot better. Go for the intake. :)
dkim113
Car: cars
sixxdeuce wrote:If you get the k&n remove the resonater and get some flexible aluminum ducting and run it from the bottom opening in the bumper up to the holes in the airbox, that way you will be getting outside air not drawing in any hot air from under the hood, like a short ram does.
ive tried this already. its a great start if youre a broke a** college student like me. but if you can afford an intake, get that instead, preferably a cold air intake instead of a short ram considering that itll be sucking in all kinds of warm underhood air. And besides, real intakes sound so much better than stock air boxes even with the resonator removed. And you'll be getting rid of that restrictive looking intake tubing as well. (but it does make your MAF sensor look real shriveled up after the install. PUHAHA!)
perpetual gyro
If money is tight, go to ebay and type in "240sx intake" and you'll get plenty of options there for cheap intakes. If you have the money though, go with AEM...and make a cold-air extension if you can squeeze it in. :)
Former_240_s14
Car: 07 BMW 335i Coupe
If money is a problem like it is to me, buy an adapter that connects to your maf with a cone filter. I like mine just fine, but if I had the money "not to metion a underbody pannel" I woulda bought me the cold air intake.
