K&N intake 2.5 problems**
All things Altima Coupe.
Tony2676
Car: 2009 Altima coupe 2.5s
Hey guys i recently noticed that mt K&N RAI for the 2.5 had an air leak on the plastic peice to connect the crankcase to the intake.
I Contacted K&N and they sent me a replacement for the small plastic vent tube that had cracked. When i recieved it i took out the old one and i tried installing the new piece, but when i tried putting that piece in it was harder to get in than the first one. It seems to me that the thread on the plastic piece does not match to the intake pipe. Has anybody had this problem??
Ricko
Car: 2008 Altima Coupe
Never heard of this before. Still have the old cracked one? Compare them.
Tony2676
yea they the same piece but the older one went in easier i was never able to screw it all the way in because of this... so it ended up breaking idk what to do... right now its just taped together but i dont like that... makes me wish i went with injen lol
fenderpicks
Car: 2010 NIssan Altima 2.5s
Lol i had to same issue as u before.
I just couldnt get that plastic into that tube and i end up breaking the plastic in half.
From what im thinking is that either there are left over plastic still stuck inside that tube's thread or u just have to slowly screw that plastic into the tube... and i was never able to get the entire plastic into the tube thro...
But overall i really have to question about K&N, because why on earth will they give you a plastic piece on a metal.....?
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
If this is the same thing as on the 3.5, and the part that Im actually thinking of, you dont "screw" that part in. It just pushes into the hose on each end and the "threads" are essentially barbs to keep it from pulling out.
elfenlied8
Car: Altima Coupe 2010 2.5S
hmm, I dont think I had that problem. It was really tight when i screwed it in but I didnt crack. also, i didnt screw it in all the way; just till i thought it was enough so it had a good seal.
Tony2676
yea i think i had to push the plastic picece in last time i installed it but i could never get it all the way in... so i left it a little out but it ended up breaking a little so i guess ima order another piece... injen's intake doesn't use plastic for the crankcase vent tube
sc20
Car: 2010 Dark Slate Altima Coupe
LOL
had the same problem when i installed mine
i was pissed when the stupid piece broke in two. The piece is not supposed to screw in ALL the way. It has a cone-shape and it is only supposed to go in so much. what i did was i got the same size screw/plug thing ( sorry for my terminology, idk what its proper term is) , but in metal. it screwed in perfectly fine and it was a perfect math for the hose. im sure you can find one. if you look at the instructions that the intake came with, it will show part J as "Vent; STRT, 5/8 Barbed 1/4 NPT, Nylon". Go to your local auto shop and get a metal one instead of that cheap plastic
Tony2676
Yea well before calling K&N i was looking for a piece that exact size but at any auto shop or any other place they had plumbing crap, but i never found one that size... so i ended up calling them and the same crap happened again when i got the piece which pissed me off!!!
sc20
Tony2676 wrote:Yea well before calling K&N i was looking for a piece that exact size but at any auto shop or any other place they had plumbing crap, but i never found one that size... so i ended up calling them and the same crap happened again when i got the piece which pissed me off!!!
Go to home depot or lowes and get the fitment from above in brass.
Tony2676
yea tried that too. They didnt have it there either... but i called K&N and they going to send me one thats been put together so i can just install the pipe with the vent connected already. hopefully they'll see what im talking about.
sc20
Tony2676 wrote:yea tried that too. They didnt have it there either... but i called K&N and they going to send me one thats been put together so i can just install the pipe with the vent connected already. hopefully they'll see what im talking about.
good luck with that
k&n should really fix this cheap plastic crap
