marlin29311 wrote:You're posting in a Versa forum - people are going to assume you have a versa and when you mention HP and TQ gains, they assume you are discussing the car at hand, not your other car.
The versa will not see a 9 hp gain from a drop in filter - the EVO has a highly modified engine, running at a much higher compression ratio that can benefit much more from the increased flow of oxygen. I still say it's garbage, and I would rather protect my engine than put on something that allows more garbage into my engine. You can't even feel 9 hp...
First off, I said in the beginning that I dont know about the Versa's gain and that I was refering to "my car."
Second I never said that a Versa would gain 9 hp.
Third, the reason Evo's get a better gain from bolt-on is because it has a "TURBO" not higher compression ratio, and last I read Evo's have a compression ratio of 8.8:1 were a Versa has 9.9:1 so according to your theory a Versa should gain more HP, just saying.
Fourth, K&N filters are not garbage. They are proven by independent shops to flow better, make more horsepower and filter just as well. Most people assume that because it flows more that it lets more crap in, but because it's a oil filter it's able to collect just as much dirt going in to the motor as a OEM filter, and even if there is a small amount getting to the engine, you must realize that it'll be so small and pointless to even reconizing because it'll be burnt up in a fraction of a second and out your tail pipe without you or your car even knowing a thing. Trust me, when it comes to turbo cars, filters are no laughing matter. We take them very serious, because what's the first thing that the incoming air flows through, our turbo. We (people and shops on evolutionm) do "a lot" of testing with filters because HP and filtration is very important!
Finally, are you serious about not being able to feel 9 HP increase. Most enthusists can feel a single HP increase, because they know their cars down to every single horsepower gained or lost, but I guess your not one of us. It's cool though.
A performance mechanic once told me, "300HP is fast, but 400HP is TWICE as fast, and 500HP is TWICE as fast a 400HP, so dont ever take a single HP for granted."
