K & N Cone Filter
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
any of u complainers have a cone u took off ur Q (6") LMK thanksjames
jamesmost
nevermind got one new for $45
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
Where did you get it?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
GreenQ45a wrote:Where did you get it?
The better question is, "Why bother?"
jamesmost
maxnix wrote:The better question is, "Why bother?"
SOOO ANGRY
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Why bother posting?
jamesmost
A friend of mine works for a large parts supplieru can get them from summitracing.com for $44.00 plus nominal shipping.I already had a flange though, when i installed it in 1997 i think it was for a supra (k&n flange)
Q45tech
Without a doubt the absolutely worst mod on a Q45 exposed to any Summer heat..........drives the MAF crazy at hot idle........without extensive insulation------- cold air covering to direct outside air in onto filter..
The underhood at idle gets > 160F.
The ecu has a upper limit for calculating air temperature [you are already exposed to summer protective software if the ecu coolant temp reading exceeds 194.9999999999999999999999F........when the MAF reads an air density of less than 80% of what it expects as normal [120F ambient] at idle..........it causes ecu to throw up and go into double protection.
As the 100F ambient [110F traffic] passes thru the ac condenser it gains 20F and another 20F [minimum] thru the radiator.........usually closer to 160F.
Takes multiple minutes at speed to drop under hood injested air temp.
As I always point out owners cause the most destruction of Q with their ideas on how to improve the years of work the engineers spent to get it close to right.
Now in winter a K&N cone doesn't cause too many problems other than ring wear and loss of compression but that takes 200,000+ miles of use.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Why bother posting?
Because this is a board that offers valuable information to its members, and has always long before you joined.
It is a tradition not to be discarded for the cultivation of fashionable ignorance.
Falkdesigns
Car: 1998 Q45t ~ EXE
Thank god it never gets over 80 where I live and there's always a cool Pacific breeze.
That said, it's nearly a year since I did the OEM filter('s). Time to call Joe.
