onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Dec 19, 2005 8:21 am
drop in would be the one that goes inside the box, hence "drop in"
Now that I'm done being an ***, the drop-in & cone will not matter.
Drop-in seems like it may work a little better - there is a cold air duct below the air box toing thru the filter. When you do cone, you remove this ducting, unless you carefully reroute/rig up a new routing system.
The cone should give you a nicer lil "scream" when you start flooring it - this is if you don't have a header/exhaust setup, otherwise that will override most of the noise.
The k&n will do fine as long as you regularly clean it (don't listen to that 100k no maintenance thing, if you read the fine print, it will say "clean as needed"/etc). Clean it as often as you feel necessary depending on the conditions you drive in - i.e. from every oil change to once a year.
The only problem w/ the k&n is that it is an oil type filter, so that sort of limits the amount of air that can come thru & if not cleaned/taken care of properly, can lead to no performance gain at all. This is where the Greddy Airinx or whatever dry type cleanable filter comes in.
It really all boils down to preference. We are probably talking 2-3whp difference here at most if you are staying n/a.
