NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Mon May 11, 2015 10:13 am
If you don't live down a dirt road where reusing is cheaper than replacing, i wouldn't mess with it
Reminds me of the oil bath air filters-i hated working on those
I do like how K&N manufactures them -they appear to be a quality product
Some filters have to hold up to a lot of air, fuel, or water pressure, PSI, or they will collapse
That problem doesn't apply most of the time unless maybe you have a boosted engine
I was told a particle count test is a great way to look at filter's performance
You have to look at cost, effeciency of the filter (what % of the particles are captured in the particle count),
pressure, and temperature. Too much pressure and temperature will wipe out a neoprene rubber gasket
but viton, polyester, or polypropolene might hold up
You can extend your paper element by taking it out and tapping (not hitting) on the concrete to unload
the dirt. I had luck blowing it out with an air compressor-but you have to blow it out at an angle and
NOT tear or stretch the filter media.
And i agree oil on the filter media will reduce the life of your MAF and just muck up your throttle plate
