JWT S2 cams on the VK56DE
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
TeKKiE
Car: '98 SE-R
Has anyone installed the JWT S2's in their Titan/Armada? If so, what are your thoughts? I notice that max power increase is ~35hp @ 4700rpm, and ~45tq @ 4700rpm, some pretty good figures considering drop in application...
Redcon
Car: 2004 Nissan Armada
If you consider new cams as a "drop in application", you must have good cash flow? Pulling valve covers, cams, timing chains etc. is good tech work !!
TeKKiE
Car: '98 SE-R
There's no cash flow involved, other than buying the cams. I would never have anyone else work on my vehicles! You know the saying: "If you want it done right, do it yourself."
Replacing cams isn't really a big deal anyway...
Redcon wrote:If you consider new cams as a "drop in application", you must have good cash flow? Pulling valve covers, cams, timing chains etc. is good tech work !!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
