dkill wrote:Do these numbers, seem somewhat on par? 90-93 Q
JWT ECU/TCU Level ten transmission Low 14x 1/4 mile, with high 90s trap speed
dkill, the trans alone likely won't improve times. It should, however, be able to withstand more abuse, like the Blue Plate clutches & kevlar bands installed in my trans, along with the valve body mods. *If* it has a nice stall converter, it *will* improve times, but be advised they have several different levels of service. AGM has a billet converter, not a standard option, I'm sure.
Elwesso wrote:When you get a JWT ECU, you get a whole new ECU correct?? You dont send them your core, and they send it back?
Its a shame JWT customer support sucks...
Yes, you send them *a* core & they send you back your same box. However, the JWT setup is *not* a reflash, but rather a new daughter board that accepts eproms for different upgrades.
For instance, you have Sentra and a JWT base program with n2o module then later you decide to upgrade to a GTIR with 444cc injectors instead of 370cc but also want to keep your n20 module with a 50 shot instead of 100, and reprogram for the different injectors. That upgrade only costs you $100. Later you go with 720cc inj & a 100 shot, no problem, $100 upgrade.
Their support doesn't suck, it's just that everyone in the world recognizes they are the North American Nissan (perhaps worldwide) authority and therefore they are constantly backed up.
Now for real-time customer service sucking, see Stillen.
Stillen doesn't make many things they claim they do, it's possible the Stillen ECU is a JWT anyway. The Stillen intakes used to be JWT POPs.
