JWT ECU Tune
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
Is it possible to get these retuned to different years?Someone is selling one here locally, and he says its for a 98.I could this be retuned for a 92 motor? Also, does that even matter as long as the motor is a DE and using the same injectors as the other car?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Your 92 ecu is much more tuner friendly than that s14 ecu.
Techically, you can run that ecu, but you will need adapter harness or repinned obd2 connector on your obd1 harness.
Waste of time, that JWT tune sucks anyways. Buy a daughterboard and tune your own ecu yourself, check out eccs.hybridka.com there are even some tunes up for download, free.
emperor_lunchbox
Very cool. I will definately look into that. Thanks.
