JWT ecu question
sli240sx
Car: 98 Nissan 240sx w/SR20det S14
Hay guys I was wondering if someone could help me out. I was thinking of buying a slightly used 96 240sx ECU tuned by JWT designed to run a turbo on a KA24DE utilizing a Ford Cobra MAF sensor, and MSD 50lbs injectors. would i be able to run that ecu in my 240? I don't have a turbo, mine is still N/A with I/H/E clutch, flywheel, LSD, and JWT cams and sprockets. would it be ok it run that ecu as is or should I reprogram it? thank
jab11185
Car: 1992 Nissan 240sx
yes you can run it NA
BUT
you'd need 50 lbs injectors and a ford cobra MAF....
EDIT: 300th post w00t!
Structure240sx
after getting those items you would lose power. the jwt is prgrammed to run richer and less total timing. this would serisouly hurt your power without the turbo. if its for a good price $300-350 tops then its only $100 to retune it to your specs. otherwise you might as well order a new one through splpart.com for $485
sli240sx
yeah the ecu is about $280, so i would have to retune it. ok thank guy.
Structure240sx
no prob, good deal on the ecu
