rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Tue Apr 13, 2004 5:22 pm
I currently have the 370cc injector program with the stock maf.. It works fine, but i do have idle problems but ONLY when I do this:
I rev up the motor to about 6500 rpm and release the throttle, then the needle will drop down to about 300 ish rpm where it will either A: stall out, B: go up to about 1000ish rpm and bounce around 2 or 3 times then restore's back to 800 rpm, or C: goes back to 800 rpm fast with NO hesitation and stays there..
Its seems to be like the ECU is picking on which method it wants to do cause its never the same responce..!!
It will also do this while im in gear at high rpm then hitting the clutch to let it coast.
Meanwhile if im reved or in gear at low rpm's below 3000, and press in the clutch to coast, it drops to 800 rpm everytime and maintains there... its like clockwork..
So if the Z32 maf program is the same, then im not loosing anything, I might as well just get that one cause im already adjusted to tapping the gas pedal when the rpm's drop to about 1000 rpm anyway to keep it from doing A, B or C...
