GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Tue Dec 02, 2003 8:12 am
I started with the JWT ECU, and, well, all i can say about it is that it works and allows the car to run. Power and drivability seem to be secondary to functionality. And it took them 3 months to get the ECU back to me. Now i have a power FC. Just running off the base maps with the settings to get the car to run with the Z32 MAF and beefy injectors, it drives markedly better than with the JWT ECU. However, professional dyno tuning is a MUST. Also, the FC has NO automatic knock retard like the factory/JWT ECU. So, it has to be tuned accordingly, or you could get a J&S Knockguard, but that and the power FC plus tuning would be like $2000.
You could just get an AFC to run the bigger injectors and the Z32 MAF. That'd be the cheapest way to do it.
