JWT ecu help
sportbikedude
i have a jwt #62 ecu tunned for z32 mas, 72# msd injectors. the guy i bought it from said it was for 550cc injectors. well after installing them i realize i need more like 740cc.
so i figure i could use some from deatch works like my 550s. i e mailed him and he said his injectors wont work with the jwt tunes. anyone know this to be true? if it is true now i gota replace my rail, injectors, and wire plugs?
also the ecu tag says "must use dropping rest." what does that mean?
thanks for any help you guys can give
FAST-DATSUN
Just like it says you need at add dropping resistor to correct the power to the injectors, If the program says 72# injector you need to use that.....
Este510
Car: spec v, 240, 510
Call up jgy customs at 276 782-9100 they will help you out.
