wild_maxx »
https://forums.nicoclub.com/wild-maxx-u17600.html
Tue Aug 30, 2005 7:33 pm
ok i have a JWT ecu 50 lb program and z32 maf. i had my safc tuned for stock kae maf and 460cc injectors but didnt change the settings for the new setup. question is, if i just disconnect the safc completely but not taking out the wiring into the ecu harness will it just run off the JWT program and no safc settings?if i want to fine tune with the safc, what should the low throttle base setting be at with the maf and 550cc injectors? thought it was around -30 or so for low throttle map across the board and lean it out more on the high map?
