Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Fri Dec 24, 2004 8:14 am
Theres also another problem with the afc and JWT combo.FWIK, the JWT ecu uses a subtractor circuit to read the voltage on the cobra ecu when its used in conjunction with the 72lb program. The cobra has an output of 5.5 volts, and when the ecu reads 5 volts, it basically cant correct anymore for the rest of the .5 volts that the cobra maf puts out(i hope im expaining this right). If you use the JWT 50lb program, then the maf is plenty for the setup, since the injectors will amx out before the maf does. If you use the 72 lb program with the cobra maf, then the sub circuit is necessary to make the most of the maf since the injectors will outlast the mafs capacity unless the sub circuit is there. Now, for the afc--it only corrects up to 5 volts. SO when the cobra maf puts out over 5 volts, then the efc cant process any more info for correction. SO it cant relay that info to the ecu. The ecu only reads a max of 5 volts (since the afc cant process anything over that) and cant correct accordingly, regardless of its tune(50lb, 72lb, stock, or JWT).
Using the afc is great for those using the Z32 maf or a 50lb cobra maf JWT program. Anything other than that, the setup is more than the afc can work with.
-Josh
