I found a JWT ECU for $250--Actually, it's a KA ECU with an SR program. Now, it costs $100 to reprogram these ECU's, correct?
I figured for that price, I may as well try it; I could always sell it and get my money back.
Anyway, I'm asking you guys, especially orion (I emailed you like 4 days ago about this, maybe you're out of town), if it's worth it for me to get it. My car runs fine as it is, and makes decent power, but I can't help but imagine how much better it'd feel with an ECU actually PROGRAMMED to take boost and a lot more fuel; I think it'd deliver a lot better power all across the RPM range.
If I'm running 9-10 psi, are 370 cc injectors big enough to use? Or should I go up another step (What is the next step? 440 cc?) And you use just the ECU, bigger injectors, and stock FPR, correct? If 370 cc inejctors are NOT big enough, could I use a RRFPR along with it, such as a 2:1? As a side note---I have consistent access to 94 octane gas--does JWT distinguish between 91, 93, and 94 octane?
I've heard JWT tunes conservatively--how conservative are we talking? I know they run a bit rich, but is it so rich as to rob a significant amount of power (I've looked at your charts, Brian, but I'm wondering if it'd be similar with another 2 psi)?
Also they come with pre-programmed timing curves according to rpm, boost, or both? How much does the timing fluctuate between the RPM/boost range? If they do come pre-programmed with their own timing, what would actually adjusting the timing manually (ie, at distributor) do? Would it just advance or retard however much you manually adjusted it, with the effective timing being whatever was programmed at that point + or - what you did to the distributor? I haven't really screwed with my timing that much (except, of course, when I changed my upper timing chain
Basically what I'm asking is if 370 cc injectors + the ECU would be sufficient fuel for 9-10 psi of boost. (Note that currently, my car drops from around 8/9 psi at 5k rpm to around 6 psi at 6k rpm, that is, it never sees a full 9-10 psi for more than 2.5k rpm, however, I may be upgrading the turbo to a .63 a/r turbine from the existing .48 a/r turbine, which would give it a full 9 psi till past 6k rpm).
Overall, is it worth the money? Basically, I want my engine just like orion's--248 RWHP at just 8 psi. WOW. Once I get a larger turbo and an ECU, I figure not much is different between our setups. (except the hacked MAF/ECU) I have all 180+ compression across the board.
I'll think of more questions to ask along with it, but this'll do for now
Thanks...marc :ylsuper
