JWT cams installed pics and more
ultimatuc
Car: fast cars, big trucks, sluts
Power between 4 and 7 grand is amazing. I'm going to dyno again next week to see what kind of power they made.
Greddy profec B and Greddy timer
225/45/17 Falken azenis sports
ultimatuc
nismo fuel pressure regulator, autometer gauge...
klattr1
Car: GT42R powered S14/KA
sweet, good for you. Its amazing how much top end there is after installing those cams huh?I like mine but I did notice some low end loss (I expected it though).It makes your torque peak hit really hard now with those cams i bet.BTW, whats your vacuum at idle like?
ultimatuc
^18- 20hg's. yeah, I did lose some bottom end, but the power gained up high makes up for the loss.
MaxType 240
Car: 1995 S14
Good stuff man, keep us updated! I'd like to see the dyno chart...Ryan, what's your idle at? Jeff in Tampa has the JWT cams and ECU and can't idle less than 1900rpm. He's confident it's the ECU. I'm sure it's a combo of the cams and bad ECU tuning.
Jesse
klattr1
hmm, thats strange.Mine idles fine at 770 rpms but my vacuum is more like 16in Hg. I'll have to look for more vac. leaks.
Projex240
Car: Dogs , My RIDE
uh oh
silkk
Car: 94 B13
89 S13
07 S2000
very cool :D
WDRacing
Lookin good, do you have a befroe and after dyno to compare to? I have to make sure I do a dyno prior to installing my cams.
WD
ultimatuc
^ yeah. I dyno'd last week. 225whp and 243f ftlbs.
we'll see. thanks for the compliments guys.
Altiman94
Car: 1989 Nissan 240SX
sweet install.
gawath
Looking great. Keep us updated.
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
What is the lift and duration of your cams?
ultimatuc
390" LIFT / 275 DEG. DUR
changed the exhaust note completely.
http://www.nexusfilms.net/vide...1.MPG
http://www.nexusfilms.net/vide...0.MPG
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
^^^ But bear in mind that duration cannot be compared to Nissan OEM specs...JWT measures them differently.
By the Nissan temrinology (i.e. 240 intake, 248 exhaust, etc...) JWT cams are more like 256/256.
Just FYI...they are not as wild as they look, but they are a great cam for the KA.
- Brian
WDRacing
Thats exactly what I was think Bri, I was actually talking to Scotty240 about this awhile back. 275 cams would definitly require cam gears to avoid a ton of overlap. For street I wouldn't go much past 264, unless your going to rev the ****e out of the motor to use the higher RPMs.
Projex240
Car: Dogs , My RIDE
even the jwt cams as teysit require cam gears ro remove the overlap. Those cams are desgned for all motor anyway. The overlap causes the cranking comp to be lower than it should be--i.e.--an 8.5:1 motor should be around 165--it ends up being like 130-140.Jwt even recommends cam gears.I like the crowers--250/250's and theya re turbo grinds--heh and only 400 to boot-no regrinds, no cores--400 bucks outright. Im getting them.
-Josh
MaxType 240
Car: 1995 S14
Crower cams, eh? 1st I've heard of them, they don't show anything online.
Jesse
ultimatuc
good info guys. I'm going to look into getting the gears.
Jeff240sx
Car: Car! Chicks!
I guess since Jesse thrust me into here, I'll reply.When I first put it back together, the car idled like a champ. 1000rpm, and right where I wanted it.Then it walked up, so I changed out IACVs. Worked another 3 days, and back up it went. The car cold idles at 1000, then when warmed up, it jumps to 1500, and walks to 1700-1900.It could be a coolant temp sensor issue, with my water temp gauge fluctuating.. or my thermostat could be stuck, and then my idle issue is still unknown.-Jeff
klattr1
jeff, definitely check your one of your water temp sensors. I thought one was for the gauge and one was for the ecu. check your connections for sure.
huguetpj
Car: 93 KAT Coupe
MaxType 240 wrote:Crower cams, eh? 1st I've heard of them, they don't show anything online.
Jesse
PDM has some nice Colt Cams one. Although they are $600
