I did last weekend, all i can say is FACTORY SERVICE MANUEL. I just followed the instructions.
Cliff notes:Tighten down from the outside in in 2 stages and i think the final tourqe spec is like 8.5 lbs.
Make sure the cams are on the correct side, it should say on the JWT website how to tell. Make sure that when tightening down the cams that it is opening the middle valves not the outside ones, if it does this will fk ur valves.
When you get them tightended down, turn the motor with a wrench on the crank pully to TDC, do this with the upper timing chain not connected.
Once the motor is at TDC look for the timing marks on the chain and the idler sprocket. Line up the mark on the sprocket with the mark on the chain, from here take the sprockets and place them lined up with the timing marks NOT ON THE CAMS yet. Once u get the cam sprockets lined up with the timing marks and the idle sprocket on the bottom timing mark then push the sprockets onto the cams. And fasten with bolts.
If it still runs like crap then make sure the cams are not laid 180 out, or the dist isnt set up 180 out.
And i just thought of something, when i was having problems figuring out why my car wouldnt start i took my valve cover off of my motor to check cam timing, and cranked it to watch the cams, my gf took video of this. If you think it will help you identify cam timing, IM me at KoukiKA240sx on AIM or email me At
[email protected] and ill send the video ur way. I hope this helps,~Sam
