Ok, i just got my Brian Crower stage 2 camshafts (int & ext) and my Jim Wolf Technology Non slip cam gears, I was installing them when i read that on turbo charged engines JWT prefers that you advance the exaust 2.5 degrees and retard the intake 2.5 degrees... is this safe to do on a stock sr20det redtop? or will i bend valves, that is deffinetly the last thing i want to do, if its possible to do please help im not too technical and every thread ive seen about this doesnt have pictures.
Can someone pleeeeeease post pics of what your cam gears will look like at TDC with the cam gears adjusted to the 2.5 degrees... Pictures would really help.. i dont want to bend valves...again. here are some pix of the products im using... i know they say to put the gears at the mark "A" but i just dont wanna risk it..
Thanks i would appreciate any help guys.
