GQ Jay wrote:yes, it does work--just not as straigtforward as the non-a.
the photo is of the d/s tower, showing the small clearance.
Thanks to Jeff and Keith for coming up with the plan to rotate the hydraulic line to increase the clearance.
NICO comes thru again!!
SWEEEEET!
I have been worrying about this for a few days. I am glad that you were abole to rotate that line, Jay. Great work! It looks like you would have to use vice grips to tighten the allen bolt, unless you were able to tighten it before you installed the bar. Once I have mine tight, it is fairly easy to remove and re-install it. I have done it about 80 times, so far.
