Shad0wXCalibur »
https://forums.nicoclub.com/shad0wxcalibur-u95338.html
Wed Jun 16, 2010 8:21 pm
If you are installing a double-din, you don't NEED a dash kit but there will be a small gap around the deck that's filled in by a single trim piece that you can't seem to buy by itself. I had to buy the whole $15 or whatever dash kit that was labeled single-din and double-din. The double-din "kit" is just that freakin trim piece. The double-din bolts onto the brackets that held on the stock radio. Unless you have the 1.6 without a radio from the factory. Then I have no idea if those have brackets or not already. If not, you'll need to get those along with the screws to attach the brackets to the dash from a dealership or a junkyard Versa. The double-din will come with screws to attach the double-din to the brackets.
