JVC DVD/NAV install pics (and some other goodies)
All things Altima Coupe.
jmann
Car: 2017 Mercedes GLC300 4matic
2015 Infiniti QX70 AWD
JVC KW-NT3HDT:
(I picked up a 16gb verbatim flash drive as pictured, the smallest I've seen.)
Not pictured: Satellite module, Axxess ASWC steering wheel control module, backup camera.
and Katzkins leather:
(Circular heat switches mounted on center console)
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
looks great!!!! How much did the katskinz run you?
jmann
It was right around $1800 installed.
rcboy514
1991 BMW 535i I-6
ok cool, also how easy was the axxess steering wheel module to install? If you did it yourself. I just ordered a double din navi and the axxess module and plan on installing it myself.
thanks
jmann
Unfortunately the ASWC was one of the hardest parts of the install, just because the instructions were so confusing. I paid to have that part installed and he told me the same problems I was having with it, the online instructions list one set of wires, the included instructions list another set... but once it is hooked up correctly it programs itself and works great. you will probably end up trying several configurations before getting it to work.
rcboy514
1991 BMW 535i I-6
yikes lol I'll give it a go and see what happens.
walshyboy1220
Im in the same boat as RCBoy, Can you think you can help us out and tell us what Wires from the Axxess have to be hooked up, The White and Green, Blue and Gray? I know im digging up a old thread, however the question has never really been definitely answered here on this board or Nissan Club
jmann
Here is how the Metra kit is wired...
ok these weren't connected to anything:
Here, the white/green from the SWC is spliced to the white/blue (or gray/blue) from the car harness wires:
The car harnesses white/green wire is connected to the SWC's pink/grey (or gray/red) wire:
This Blue/Black w grey notches from the car harness is connected to the ground wire:
I think all that leaves is the power wires and the one that plugs into the mini plug from the back of the JVC.
walshyboy1220
Ahh yess I just tried this. I found it on Nissan Club last night. However There is no Gray/Pink wire however there is only SOLID Pink and Blue with Pink Stripes, and Gray and Red
Can you be a huge help to not just me but everyone looking for this to tell us what Pins on the Axxess is connected and what pins on the harness are connected like the Physical numbers IE 1, 2, 3 , 4......
Thanks
jmann
Sorry that is the best I could tell from that mess of wires behind there. Maybe they changed the color schemes of the wires? I know the solid pink and the blue with pink stripes from the access module are both not connected to anything. That might be a pink wire with a blue stripe instead of gray, it's hard to tell from the picture and I used them as reference when writing these instructions, I should have written down something more specific I guess.
jmann
for clarification, this is the kit I have:
walshyboy1220
Jmann, I have the exact same thing and everything i just picked it up from crutchfield last week, it comes with a install manual and application chart. However from reading the manual the only has these wires
Pin 1 – Pink
Pin 2 – White/Green (Using for White/Blue)
Pin 3 – Orange/Green
Pin 4 – Green/Orange
Pin 5 – Gray/Red
Pin 6 – Black (Gorund)
Pin 7 – Blue/Pink
Pin 8 – Black/Green
Pin 9 – Red (Tip of 3.5mm connector)
Pin 10 – Whie (Ring of 3.5mm connector)
Pin 11 – Gray/Blue
Pin 12 – Red
I went ground and red obvi, then the white/green to goes to white/blue. the blue with gray notches goes to ground on the harness. Now which wire from those 7 remaining wires connects to the vehicle harness which is (White/Green)
Thanks
jmann
Try the Gray/red wire, that is what it says to connect from the online instructions here:
http://contentdocs.installernet.com/doc ... /10972.pdf
although my module did not have a wire that color. It has to be the one you will need to use...
walshyboy1220
T taped it all in and tried it, still no avail. I reset the system too, this time all it has done is turn the volume down to zero and then quit working and went into standby mode. If its not too much trouble can you be more specfic on the Pin placement on which wire it is on the AXXESS harness? This really would clear alot of things up for people who would want to be a DIY for steering wheel control guys like us who have aftermarket HU
jmann
Did you hold the volume up button per the instructions after you reset it? it sounds like you had it correctly hooked up if the volume started going down. Again, I'm not the one who installed this in my car so I'm afraid I've given you all the information I can, given the wire colors on my unit did not match the instructions I had or the wires on your unit.
walshyboy1220
Got it!
Ok so heres how it all goes.
White with Green Stripe (SWC) to Gray with Blue Stripe (Harness)
Gray with Red Stripe (SWC) to White with Green Stripe (Harness)
Blue with Black Stripe with Gray Notches (Harness) to Ground
And
12V to 12V Source
Ground to Ground
Aux Connector (From SWC) to the Wired Remote Input on the back of your Headunit
walshyboy1220
Jman,
Thank you again! I actually did not have to touch anything. When the wires were all hooked up and turned it on it started to work right off the bat
jmann
I'll check it out one more time and let you know what colors go in what pin numbers, but it will be later tonight before I can open it up and check this out.
**Edit - NVM I just saw your post...Sweet! glad I could help out a little!
