CocDiezel »
https://forums.nicoclub.com/cocdiezel-u105934.html
Tue Oct 21, 2008 9:20 am
Here is the response I got from the seller... oh, btw I had my buddy who runs a tire / mechanic shop do a PPI for me too before I bought it.
"Hi Michael,
That email made me laugh out loud, and it made me a little mad. Wow. I don't even know where to start.
There is absolutely no obligation to have regular service work performed by a dealership to maintain your warranty. In fact, you could do all the stuff right in your garage as long as you don't screw anything up. The proof of burden in denying a warranty claim lays with the dealership. If you failed to clean your air filter for 3 years and clogged something up, somehow destroying a certain part, the only part of the warranty is affected would be that particular part. There's a federal that pertains to this, it's the Magnuson Moss Act. If you add an aftermarket intake to your car and the mass air flow sensor goes bad, then you might have a problem. If the transmission dies, then that obviously has nothing to do with the aftermarket intake. Same goes with the exhaust. If an O2 sensor goes bad, you may have a problem....but the only part of the warranty that is affected will have to do with that part of the warranty that covered the OEM Infiniti exhaust.
As far as the 30,000 mile service goes, yes it is due. However...check VERY carefully what they're charging you for. Ask for a list of things that they perform and only authorize them to do those specific things. The car is only 2 years old and with 30,000 miles, you certainly don't need the radiator flushed, or the air filter changed, the brake pads replaced, and so on and so forth. If I still owned the car I'd probably have the automatic transmission fluid changed, but this is something you can do yourself, or something that probably costs less than $100.
Sorry if I'm going on about stuff you may already know, I'm just picking apart his horribly innacurate email.
As far as the car being towed, it did need to be towed to a dealership in Los Angeles when I was on my trip to Florida and back. The dealership there tried to (unsuccesfully) tell me that my aftermarket intake system caused the car to quit running. The supposedly "did" something to fix it and when I left the car died again. I then got into a very heated argument with the jerk service manager (who sounds very similar in opinion as this guy you got the email from) who in essence kicked me out and sent me down the road to another dealership in Los Angeles. Within 5 minutes the other dealership found out that the main ECU had a grounding problem and they replaced it under warranty without any quesitons whatsover about my intake or exaust. So I'm sure that's what the guy you got the email was talking about, even though his facts are WAY OFF.
It really, really sounds like he's just trying to talk you out of buying somewhere else because - let's face it - hardly anyone is buying cars right now in this awful economy.
I say this with absolutely NO reservation and I give you my word of honor that the car is tip top, was well cared for, and should provide you with many years of trouble free service. In fact, it'll probably be better than it was when I owned it, because the bad stuff (the ECU needing replaced) has already happened when I owned it. And like I said in my online ad, the car was run 100% flawlessly since then.
It's an awesome car. I wouldn't worry about that guy's email. Having said that, anyone can run into problems at the service department (like me.) Just stand up to them and know your rights about service and warrantly laws. I've run into almost as many jerks at the service department as I have in sales. It's REALLY frustrating sometimes.
I hope this helps and sorry for rambling.
Tony"
