YamaOni »
https://forums.nicoclub.com/yamaoni-u3783.html
Fri May 16, 2003 4:07 pm
Try the CAS at center , And check the all conections and the grounds. Is the fuel pump kicking on and off? Also chack the MAF. Do you have a SAFC? Is it hooked up? If so check for RPM on the SAFC, If the engine is cranking and the SAFC RPM is 0 the CAS might be bad.
