just wondering
mordakibojangles
Car: 89 240sx
My car is an automatic with an akward idle When my car is in a park or neutral it idles at 1200 and then when i put it in drive it idles at 700
junkyard cams
so what are you wondering?? what is the question
mordakibojangles
Car: 89 240sx
is that normal
themadscientist
A little low, but for a 23 year old car not bad.
alms24sebring
'04 Nissan Sentra SER SpecV
Id say thats fair. Its supposed to be around 1200 or a tiny bit more when its cold. 700 or so is fine, you have nothing to worry about
junkyard cams
Is this only when you first start it, or even after you've been driving
Totally normal.
Could probably use a good throttle body cleaning and cleaning of the Idle Air Control Valve (both of which we can show you how to do).
mordakibojangles
Car: 89 240sx
alright thinks for the help i cleaned the throtle bod cant really find out how to remove the iac
mordakibojangles
Car: 89 240sx
and is there a certain cleaner i should use to clean it
