frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Fri May 06, 2016 5:23 am
If you jump timing, any of those things might happen. However, I wouldn't continue trying to run the engine. Your best bet in there, take off the waterpump and front cover, and inspect the timing chain (belt?).
Normally you'd use a timing gun, but if the engine isn't running, that won't work well.
