just won these...
thekage
Car: 98 Dodge Caravan
98 Dodge Intrepid
http://cgi.ebay.com/ebaymotors...%3AIT
To install, do I have to remove the bumper cover?
Altiman94
Car: 1989 Nissan 240SX
why did you bid on those? They are the exact same thing as the USDM ones.
thekage
98 Dodge Intrepid
im a nissan noob. Looks like black housing and a thousand times clearer than my headlights. Ive tried to de-yellow mine twice now based off instructions from here... and they clear up for about a week.. then its yellow all over again.
ELITEBB127108
shouldve just got the kouki lights....
Altiman94
you shouldnt have to remove the bumper cover to install these.
pinoi007
wow.. i only spent less than $20 to get the yellow out.. not $240.. anyways.. you have to use automotive sandpaper.. going up gradually to 2000 grit and wet sanding.. use 3M rubbing compound to fill in the 2000 grit scratches.. then use plastic polish...
Ceptos
Car: 95 240sx
pop the hood, unscrew the radiator grill, loosen the cornor light, take out the headlight lamp. from what i can remember i had no idea what to do when i started, and it was very wasy, becomes apparent as you look at it.
v0va
werent the jdm zenki headlights clear ?
Adikt
can i have ur old yellow ones?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
yeah i thought JDM headlights were glass
